Techlink stand
Whitdragon
Techlink stand
Can you fit a techlink strada stand to a W6 TV
Thalamus.
Champion
Hi Whitdragon,
welcome to the Sony User Community Forum..:smileyhappy:
I guess if the Techlink Strata TV Stand is VESA compatible then it should fit, check the specs of the stand to ensure the screw holes align correctly, etc & that it can support the wieght..
According to the Curry's/PCworld website they selll the ST90D2 Strata TV Stand with Bracket & also stock W6 Bravia so may be worth checking with them or even better see if they can put one on the stand to see if you like it before purchasing..:smileywink:
Failing that see if Tecklink or a specialist TV Mounting firm can give you any advice..
