TV (KDL40EX500) wont go to sleep mode / standby on HDMI
bizkit45
hy, TV wont go to sleep mode over HDMI. If i put it on VGA, TV goes to sleep after some time, but if i put it on HDMI (tryed all 4 ports) the screen just goes black (not OFF, green light is still on) and saying it is pluged in to HDMI with white fonts in top right corner. I am trying this on PC.
Hi there
Fully heard and understood now :slight_smile:  Thank you for the full explaination.
But unfortunately it cannot be done.  Ill explain.
Under the ECO settings, there is an option for PC Power management - But only from the PC input Source (ie VGA).  There is no option to power down the TV from any other input source.
Looking at the HDMI settings - Even IF the PC was compatible for HDMI-CEC functions (Bravia Sync)  which it probably isnt, there is still no way to switch the TV off.  You are able to have the TV switch itself on via a compatible connected device, but not the other way around.
Your only option is the Idle TV standby setting/presence sensor (if available) but they have some drawbacks if used too.
Anyway, hopefully this explains it.  Unfortunately, its back to that remote control power button.
4 REPLIES 4
Hi
Im not sure what you are trying to achieve here.  However I am not aware that you can automatically turn the TV off over HDM if no HDMI input source is detect.
Have you looked into the ECO settings in the System Settings - In particular "Idle TV Standby" or even Presence Sensor.
http://pdf.crse.com/manuals/iManuals/egb/3a-1/eco_2b1_2b2_3a0_3a1_3a2_50.html
bizkit45
maybe i was not clear enough :slight_smile:
i have PC hooked up to THIS TV (via HDMI) and another standard monitor (via DVI). Now i want TV to turn off after PC being IDLE (meaning 20min inactivity). The monitor which is on DVI turns off. The TV did turn off while i had it hooked on standard VGA, but now when i replaced VGA for HDMI it is allways ON. The PC and monitor both goes to sleep and turn off, but the TV is always on even if i turn off PC.
I hope i made it clear enuff this time :slight_smile:
thanks in advance.
Hi there
bizkit45
thanks for the detailed explanation.you made it very clear and easy.
