TV KLV-30HR3
ifield9
TV KLV-30HR3
TV New to me. Trying to set up using Digital box converter. Nothing. Zip. Nada. Help please before TV is thrown through window.
etritd
Hello! I can see you are very frustrated.
Anyway I don't see there is much to set up to make your TV work with your Digital box.
After you connect them using either scart or rca cable and make sure the digital box is on, you turn on the TV.
Press the Input button input buton symbol.JPG on your remote ( the second right-top button, the one under on/off button) or on your TV set (the second from left) repeatedly until the input symbol of your desired source appears on the screen and you see the picture from your digital box.
