uneven frame....
Guy_88
uneven frame....
The black frame on the lcd screen is uneven, is this normal or should I get it replaced?
I don’t know if it has just been badly built, i have attatched pictures, you can clearly the right side is coming out more than the  left
Hi there,
Support should be able to advise on this. Here is the link for you: http://bit.ly/1Yo3R6C
Let us know how you get on. :slight_smile:
Best wishes,
M
Guy_88
I did this this morning.
i’ll keep you up to date, no problem :slight_smile:
Hopefully it’s nothing as I can’t be bothered with the hassle of replacements, but something is telling me whoever built this TV has done a poor job hence why the border is a bit uneven.
