Useless browser keyboard
stevemalyj
Hi
wondering if there is anyone having the same problem or a known fix for this...
I have a sony bravia KD-49XE7002. Overall happy with it but the browser is pathetic. Well, not the browser but the keyboard on the browser. If I go into a search box within a website or if I generally try and enter a url, I type it in using the on screen keyboard and then go to “enter” and it does nothing. It’s as if the “enter” button isn’t the trigger to then run the search or transport to the url. So if the page or search box doesn’t have a “search” or “go” button next to the text box, your screwed.
What the hell! Is this a known problem. I nearly put my foot through the tv and sent Sony the bill.
Mick_D
Moderator
Hi @stevemalyj, welcome to the Community.
I'm not familiar with that model, but it should have the Opera-based browser so the process of entering text, URLs etc would be pretty standard.
Have a look at this online guide, which will hopefully explain things in enough detail.
Mick
