VC-1 & KDL-42W805A
profile.country.SK.title
mfoldes
VC-1 & KDL-42W805A
Hello,
I have brand new Sony KDL-42W805A and  I have to question to us, if this model really doesn't support VC-1 codec in MKV. I make lossless backups from my BDs to external HDD and I can´t play ripps which are in codecs VC-1. In .H264 forks fine.
Thanks for your respons.
4 REPLIES 4
Hi there
I really dont know your exact question, however the supported codecs are listed : HERE
mfoldes
my question is, I mean, absoluelly right, because my previous Samsung LCD LE32C650 has also indicated in manual, that VC-1 is not supported, but it can.
So, is there chance, that in the future it can do?
I cant predict the future :slight_smile:  However, I would say that its unlikely, but if you want, try emailing Sony and see if they have any plans.
mfoldes
It is really bad, that TV with cost arround $1000 unable to do this. I don't understand it.
