wifi connection on Bravia TV
paulliley
I have bought a Bravia 46HX853 and I use a BT homehub 2 router. On trying to setup the TV it is not 'finding' the router when scanned. Can anyone help please. Much appreciated. paul
Catmambo
Hi
Strange as the wireless is really good on that TV. Are you able to conect via Ethernet to update the TV firmware first? You can also do this via USB if the TV is in a totally different room. This then might make resolve the issue.
