Hello,
Does anyone has been able to connect 2 external monitors or displays on a vaio with docking station?
I have the notebook (AR31S) scren, an extended monitor with dual view and I woul add to the second external connector a second external monitor.
The computer does not recognize that there are 3 displays and plays with the main one and one of the externals.
hi with the docking station it will only tell the laptop that there are now 2 screens connected
(the only way to get 3 screens is to use the laptop screen output on the laptop graphics card and then the one on the expansion dock)
but this wont always work.
hope this helps rcrespi
Hi rcrespi,
welcome to Club vaio..
Unfortunately without additional hardware you can only attach one monitor to your Vaio..
However something like the Matrox Dual head to go should allow you to connect 2 additional monitors to your docking station..
