Hoping someone can advise.
I need to do a system restore on my laptop but the restore folder is empty and dont remember getting any cd's on purchase.
I have tried to "register my product" on the sony e-support but it dont recognise my serial number
any help appreiciated
cheers
joe
Hi Joe,
welcome to Club Vaio..
Could you please confirm you model number as VGN A127M does not appear in the list of models ..
opps, what a plum I am.
the model number is VGN-A217M
Hi Joe,
According to the specs your Vaio does not have a HDD recovery partition and you therefore should have been supplied with a set of recovery disc's..
If you are unable to find the recovery dics set that was shipped with your Vaio then you will need to contact vaio-Link to purchase a new set.
You will need to have registered your Vaio so I have included a guide on 'Where can I find the serial number of my VAIO computer?' , if your still having problems contacting Vaio-Link or registering your Vaio let us know and we see if we can help further.
Thanks for replying so quickly. I will have a look for the disks tonight.
I have tried to register again still with no luck. Strange thing is, when I put my serial number on the main support section here http://support.vaio.sony.co.uk/index/index.asp?site=voe_en_GB_cons it finds that i am using a VGN-A217M
well, I have some good news, I have found the recovery disks so doing the system recovery wont be a problem. :smileygrin:
Still think its a little odd that vaio-link (e-suuport) dont recognise my serial number when the normal support part does
just noticed, you replyed to my last post within seconds
