hi
my vaio came installed with two of these little memory sticks one in two and one in four( i think)
what i wanted to do was install another two in the empty spaces and was just woundering if any of you know of anything i need to watch out for before installing them
thanks
regards ben
Ben,
The only thing I can say is make sure they're compatible with the board and what you have in there at the moment.
looks like i will have to be conntacting the sony crew once again as they are very secretive when it comes down to the actaul spec of things
