hi.
just got my new laptop, im very impressed apart from one small problem. when playing some of my games, (quake3, need for speed underground etc) The screen hangs then the computer locks up. has anyone else had this problem and found a way to resolve it.
thanks.
Seán
Could be overheating.
Is the machine hot?
Have you changed graphics drivers?
Sean,
It's not overheating on the A series, it's the crap graphic drivers that Sony supplies!
You will find this happening on many games!
Try the Omega Drivers (www.omegadrivers.net), I have found that they work very well on my VGN-A115Z. :smileygrin:
But use them AT YOUR OWN RISK, they are not offcially supported. Also DO NOT use the overclocking facility, it will damage your graphics chip!
Using the Omega drivers I can get c. 40-50 f.p.s. from DOOM3!
:smileygrin:
Hope this helps!
CW
Ah I see, it's about time Sony updated those damn drivers
i have absolutely the same problem with my A197XP. and i also guess that it is because of the damn driver. i would be very glad if anybody could describe how to use and install the omega drivers correctly. caus i tried and failed once. thanks!
Keep going back thorugh the posts!
I wrote an article about precisly this a few weeks ago!
I will try and find the link! :smileygrin:
CW
damn drivers!! does not any sony techs see all these complaints. sell the notebook and do not care. anyway who asks if there are driver updates when purchasing a computer...
Yeah I'm so glad I didn't get the A series in the end like I was planning back in May, seems to me they have faulty DVDs, bad graphic drivers and lack of support.
You'd expect better for £1500+
Shame
Yeah I'm so glad I didn't get the A series in the end like I was planning back in May, seems to me they have faulty DVDs, bad graphic drivers and lack of support.:smileyshame_on_you:
