About PCI drivers and sound problem
zvalas
Hi everyone,
first i'm sorry about my bad english, i'm trying my best... :smileygrin:
I just reinstall WinXP Pro(SP2) on my FS285B and now have some problems:
1.I c'ant find any driver for PCI device, which are not properly installed. I tryed every posible driver from this website.
2. and also Realtek sound drivers not working, possibly cause first problem, i d'ont really know. Sound not playing throught laptop speakers neither audio output. I can hear sounds only throught my VoIP mouse VN-CX1, it is showing as USB audio device and only audio device on my laptop. I hope you understand, that i'm talking about. Thanks a lot for any advice
rich912
Hi zvalas and welcome to the forum.
Prior to installing the Audio driver you need to first install the UAA High Definition Audio Class driver. This is available from the pre-installed driver download, for your model, on Vaio-Link.
If this has no effect the have a look at this
thread.
Go n-éirí an bóthar leat
zvalas
Thanks a lot Rich912,
second opinion helps me.
I had the KB888111 driver installed and now it's works fine.
Thanks again, goodman :clap:
