Adobe
@9394724706007333
Adobe
I have uploaded Adobe Acrobat X trial version but want to revert to Version 8 which was preloaded. Original version overwritten where can I recover it from?
rich912
You should be able to re-install Adobe Acrobat Standard by using the Vaio Recovery Center.
Click ‘Start’ – ‘All Programs’ > expand the folder and click on VAIO Recovery Center.
Click Reinstall Programs or Drivers – continue through the next three windows and located Adobe Acrobat Standard – tick and continue.
You may possibly need to remove Adobe Acrobat X trial version first.
Rich
Go n-éirí an bóthar leat
rich912
Rich
@9394724706007333
Rich
Many thanks for your prompt response and guidance which has worked. I really appreciate it
John Y
rich912
You're very welcome John :slight_smile:
