AR21M S-Video Input
viewtiful
AR21M S-Video Input
Can't seem to get this to work can anyone help.
I've set it up at the moment as
Playstation 1 (w/lcd monitor) ----SVIDEO CABLE------ AR21M S-VIDEO IN port.
And then in the Red/White connectors are in a convertor to 3.5 jack and plugged in the AV port.
Is this correct? If so how do I start the screen up in S-video mode.
The LCD Monitor is showing the screen fine so the PS1 is fine and happily runs alongside composite normally.
EDIT:
Have managed to test connection by going into Windows Movie maker and it displays fine, but audio is non-existant (Will connect to speakers soon anyway) but this isnt a convienent way to play games so does anyone have any tips/ programs to run them full screen etc
0 REPLIES 0
