AR21M TV usage
Bystander_8
AR21M TV usage
On my AR21M, after connecting TV antenna, :slight_frown: I don't seem to be able to make the TV active. Using the remote control, I navigate through the Media centre software to TV then try to activate and it says' HARDWARE NOT FITTED or HARDWARE DRIVER NOT INSTALLED' this laptop has these by default! Why can't I make them work?
Dekesh
Hi there I have an AR11m and had the same problem. I solved it by following the steps in the first post in this thread: http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=36767
hope this helps
