This driver is really really old, du you know if i can find an update somewhere?
There are no updates on the sony website and i cant install drivers directly from ATI
There are no updated drivers supported by Sony.
You could have a look here -
Omega Drivers
You should be aware that these drivers have not been tested by Sony and may cause problems - you have been warned !!
