Backup CD for Vaio VGN-FS415E
mr_oeli
:slight_frown: Hi, I need the backup CD for the Vaio notebook VGN-FS415E, I forgott to burn the vaio files and had install Windows XP Professional instead of the Home Editon. But I didn't overwrite the system, first I deleted the Home Editon and intalled
Professional and loosed all the vaio files and programs..... I new it was a stupid fault but I hope anyone can help me
Thalamus.
Champion
Hi mr_oeli,
Welcome to Club Vaio, :slight_smile:
Did yo change pertition sizes when you installed XP pro?
If not then the recovery partition on your hard drive should still be there.
If you wish to restore your Vaio to as new follow the procedure for recovering your FS415E
If you did resize the partitions and deleted your recovery partition then you will have to request a new set of recovery discs from Vaio-Link
mr_oeli
maybe anyone has the (backup) dvd and can burn it for me or knows anyone a better idea to get this dvd???
mr_oeli
PS: Thank you Thamalus for your help......this was a good reference....
