Very annoying laptop problem!
matt_s
Every so often, my laptop's screen will flicker off.
That's it. No warning. No reason why. The computer continues to run, but the screen has effectively "switched off".
When I close the laptop's lid and bring it back up again, the screen has come back on again. But because I have closed the lid, the laptop is automatically going into stand-by mode.
And whenever my laptop goes into stand-by mode, my wireless connection is broken. For some reason I can't always reconnect after recovering from stand-by, so I have to reboot the computer.
Help! Why on earth does the screen flicker off when it feels like it? How can I fix this?
kee-lo_
Could be a dodgy cable, or the inverter is going.
Contact VAIO-Link for a repair
As a temporary measure, you can change the settings under power management to "Do Nothing" when you close the lid!
:wink:
