Battery light remains the same
lgourlay
Re : Laptop VPCEB4JOE - 6mths old
When I initially switch the laptop on the battery shows charging but once the main screen is showing it reverts to showing "not charging" but the battery remains at 80% and does not go down or up apart from when its on battery power only.
As the charge remains the same I can only assume it works fine with mains power but WHY won't it charge the battery to 100% and show the battery as charging ?.
:thinking:
rich912
Hi Igourlay,
This is normal - you have the battery care function enabled.
You can change settings for this in Vaio Contol Panel > Power Management > Battery Charge Functions > Advanced.
Rich
Go n-éirí an bóthar leat
rich912
Hi Igourlay,
Rich
lgourlay
Thanks Rich,
It works a treat..:smileyhappy:
rich912
You're welcome lgourlay :slight_smile:
