battery problem ! please
profile.country.ro_RO.title
vipward89
i bought my sony vaio 3 months ago , its vpcsb series
from then , the battery always showing that it is 80% charged , even if its full ... can someone explain this to me please ? or how to fix the problem ?
Message was edited by: -Cass-
rich912
Hi vipward89,
You have battery care enabled.
Open Vaio Control Center > Power Management > Battery Charge Functions – here you can disable this function or adjust the settings via the Advanced tab.
Rich
Go n-éirí an bóthar leat
rich912
Hi vipward89,
Rich
vipward89
thannk u man
rich912
You're welcome vipward89 :slight_smile:
