BIOS PASSWORD (MOT DE PASS DU BOIS)
G.
I forgot my BIOS password. How can i clear current password to get access to the bios features ?
J'ai oublié mon mot de passe du Bios. Cela fait trop longtemps que je l'ai mis. Comment initialiser le système pour accéder au BIOS ?
Vous pouvez me répondre :
5 REPLIES 5
kee-lo_
rich912
See this
Kee-Lo - the link is not working at this end:smileyconfused:
This is possibly the thread that you are linking to - click here.
Go n-éirí an bóthar leat
kee-lo_
Yeah well that f**kwit search engine isn't working....
feederfan
If you dare... open up your VAIO and remove the battery from the motherboard for 5 mins. Then re-insert the battery and your BIOS will be re-set.
rich912
Most notebooks, but not some of the more recent ones, have a reset switch on the underside, which has the same effect. It is a small hole of approx. 2mm dia. - a paperclip usually does the trick (when powered down) - but not too much pressure!!
