BIOS Upgrade for PCG-F160
mlewis
Hello.
My problem is that the grpahics are not in high definition but a kind of VGA poor quality. I thought the solution could be to flsahs the BIOS, so I downloaded the files phalsh2.exe and platform.bin. I booted in DOS but I get a message on running phlash2.exe that the platform.bin file cannot be loaded
Thanks in advance for you assistance
5 REPLIES 5
Hi mlewis and welcome to Club Vaio (at last!)
What Operating System are you using? I think these old BIOS Updates only work with W2K.
Are you using the correct Video Chip drivers for your OS?
:thinking:
mlewis
Hello
I'm using Windows 2000. No idea about the video chip etc.
What can I do.
Thanks, Mark
kee-lo_
I think Sony has ended support for the F160, which is a pain
mlewis
Well, drivers are available but they dont seem to work
mlewis
Even if support has ended, the files are available and if they dont work, what [else] can I do?
