Black screen with green dots!
amedrage
HELP! My Laptop VGN-FZ31Z was running fine, now it has a black screen with green dots all over it.  I'm sure it is an expensive repair - any ideas?
rich912
Hi amedrage,
You may very well have a faulty NVIDIA chip. If so this will be repaired free of charge within the first four years of purchase.
Have a look here:
http://genesis.sony-europe.com/instranet/ccil_sony/selfservice/search.jsp?DocId=53420&l=en_GB&m=VGN-...
Rich
Go n-éirí an bóthar leat
rich912
Hi amedrage,
Have a look here:
Rich
pctech33
You should determine the exact component that is causing the issue of a black screen. For this, restart the computer first in Safe Mode. Before troubleshooting, first take a backup of all the system files. Then determine which component is causing the problem. Find the extent of the damage caused by this problem. Then measures should be adopted to solve the issue. If the issue cannot be solved by you alone, then Sony customer care should be contacted.
http://forums.cnet.com/7726-19681_102-5188835.html
_______________
Life is too serious to be taken seriously http://imagicon.info/cat/12-13/text-smiley.png
