Blue screen of death
skykit84
Hi all,
recieved the above today strangely.
I've noticed the laptop running very smoothly but after a software update on Windows Update last night... I could not shut down (got stuck on the desktop wallpaper but no icons/taskbar etc)
I forced shutdown after 10minutes but noticed same thing today
When turning it back on, I got the Bluescreen
it is:
0x0000008e (0xc0000005, 0x804eeead, 0xb9dadb90, 0x00000000)
No Dll's or drivers mentioned at all.
Strangely, on next bootup (which is successful) Windows didnot state anything like it had recovered from a serious system error or whatever it comes up with normally after a bsod?
Hi Akash84,
Does anything HERE help at all?
:thinking:
Leetay
Hi
Try these guys, I have had loads of BSOD's over the years and they seem to know the cause if you post the info as you have done on their forum!
http://www.pcreview.co.uk/forums/
Hope this helps, as i know how you feel.
Lee
robpaxton
See if you can start the computer in Safe mode - if you can then try restoring the system to a date prior to the windows update using System restore
