Blue Screen.
alexxClarkk
Blue Screen.
okay so my laptop (System Model     VGN-NS30E_S) (model PCG-7164M) keeps coming up with this blue screen thing. Once it has done its whole restart thing it comes up with this box that says 'check for solutions' it then says ...
Intel graphics driver has stopped working properly.
A driver update, if available, might prevent this problem from recurring.
I've been through the options trying to find an update but can't find anything.
Can anybody help ?
If you go to the Intel website here: -
http://www.intel.com/p/en_US/support/detect/
You can scan your Vaio for the latest Intel Graphics Driver and install it.
:wink:
alexxClarkk
I did what you said and it said i had lastest stuff and then this came up..
A customized computer manufacturer driver is installed on your computer. The Intel Driver Update Utility is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer.
if you could help me figure this out i would be so happy :smileygrin:
ahh i hate computers.
