Hi !
Since I updated XP SP2 my software BLUESPACE doesn t work any more ! I tried to re install with the restore cd, but it didn t find this software on this cd ! help !
And same with the pre install software ! it is not on this cd ! why !
Check Vaio Link for any updates for your computer prior to installing SP2.
Some computers don't use Bluespace after updating to SP2, they use SP2s inbuilt bluetooth support instead. Vaio Link gives details on this as well.
Hi RobPaxton,
Thanks for your email received.
I already checked for the new update for my computer, and the bluetooth is still not working ! When I tried to send or receive any file via bluetooth the computer doesnt accept the file ! why !
It does seem that Bluespace does have some issues with SP2.
I suggest you use the Windows XP Bluetooth drivers (in control panel), they are much better than the rather pathetic Bluespace anyway!
CW
Yeah I usually tell people to dicth Bluespace NE too Woody
