Hi all,
I have ¨a pcg-grt896sp that I have updated with the latest sony updates, firmware and windows sp2.
My problems are that my (pioner) cd burner crach after a few mn and says that's an error has occured.
Later I can t see any file on these cd or dvd (on another computer yes).
Any idea?
Thanks,
Hervé
Which software do you use to burn DVDs/CDs?
Drag n drop cd dvd
Thanks,
Hervé
Try reinstalling the drive in device manager - this should solve the problem.
EDIT: If you need instructions I will post them here.
