Can anyone explain to me why my notebook has a C: drive and a 😧 drive and what I should use the 😧 drive for?
Sony exoect you to use the 😧 for storing documents and other important stuff
The C:\ partition is for Windows XP, programs and software.
The D:\ partition should be used for your personal files, documents, music etc, SonicStage and DVGatePlus use this for temporary and permanent storage.
The reason why you should use your D drive is because if you ever need to reinstall from the DVD disk/CD set/Recovery Partition (delete as appropriate) then by doing a standard recovery the C dirve is formatted to factory default and the D drive with your data on it is still intact...
I hope this helps!
Damn!
Kee-Lo you post too quickly mate!!!:smileylaugh:
Hey it's all good.
