I have a PCG-GRT815M and the system can not burn a DVD.
I have tried several burn programs as DVD drop, nero, etc but without result. I am using Windows XP.
Who can help me? Thanks in advance.
Opie
I have similar problems with a S2XP. Basically, the burning procedure fails usually between the 25% and 50% of the process. I have tried Nero and Alcohol 120%.
I also tried the supplied one by Sony (Sonic RecordNow) but I did when Nero & Alcohol were already installed. Sonic appears to burn until the 100% but with errors. In any case, I would like to use a software that allows me more flexibility and features like Nero.
I have heard that Nero (I think) does not work very well with my DVD recorder. Is this true? Any ideas/suggestions for our problems?
Alcohol 120%
Many thanks will follow those advices & try.
Hallo JamesMold,
Thanks for your reply.
In my notebook 815m is installed a DVD R/RW unit.Sony DW-U50A). Burning a CD is giong well. Reading/playing a DVD is going as well. Burning not. Arasing RW DVD is going wrong too. He gives the error "Illegale disk". I tryed severall DVD's, but all the same problem.
Opie
