buzz or hiss
drscatiggio
buzz or hiss
Just after having upgrade my VGN-A517B to Vista a hiss or buzz comes from the bottom side NOT from the speakers; This happens only when the lap is unplugged and stops immediately if plugged.
Any ideas?
Thamks
rich912
Hi drscatiggio,
As your model is not yet fully supported by Sony for Vista I can only assume that this is a power management/driver problem. I doubt that the VGN A series will ever be fully supported for Vista :slight_frown:
Go n-éirí an bóthar leat
