Can i connect my Notebook with my TV?
Benz65
Hi i wanted to know, can i connect my notebook with my TV?
I have a VGN-NR11Z/T notebook and a VGA connection and my TV too.
Please help me
6 REPLIES 6
If your TV has a VGA connection then I think you need a normal D-Sub 15-pin Monitor Cable like this one: -
http://www.amazon.co.uk/HD15M-Quality-Monitor-Extension-Cable/dp/B000747OFS/ref=pd_bbs_6?ie=UTF8&s=g...
If you want sound, you will need to connect your headphone socket to your TV audio in. You will need something like this: -
http://www.amazon.co.uk/Profigold-BA-PGA3402-Stereo-Audio-3-5mm/dp/B0000BX71S/ref=sr_1_1?ie=UTF8&s=g...
:wink:
Benz65
yes i have a d sub cable but i dont't know how i can change or adapt the resolution from my notebook to my tv.
Do you know how?
Benz65
can someone say me how i can adapt the resolution from my pc for my tv
Benz65
can nobody help me?
jeffer
Your tv will never have the same resolution as your laptop. A TV is not as sharp as a monitor. Can you get a picture at all on your tv? If you can, then that's all you can do. If not, make the connections and use Fn+F(something) - the one that changes the display output.
Benz65
I have not mean my tv with the resolution, i have mean my laptop if i can change there the resolution for the tv
