Can I upgrade RAM memory on my SONY VAIO VPCF12Z1E higher than 8 GB
Can I upgrade RAM memory on my SONY VAIO VPCF12Z1E higher than 8 GB, or is 8 GB the maximum supported?
rich912
Hi grozescu_stefan,
8192MB is the maximum manufacturer supported memory for this model.
Rich
Go n-éirí an bóthar leat
