Can't get DVB-T in XL201 to work
andysp5
I have an XL201 with a Avermedia DVB-T card in it. I have checked and this is configured and working correct in Device Manager. I have managed to plug in my Sky box via Composite cables to the DVB-T card, and it recognises this OK (Quality is c**p so I use Sky direct to the TV for now....).
However, I have then disconnected my arial cable from the TV (which has it's own DVB-T) and plugged it into the Avermedia DVB-T card in the XL201. It then can't pick up any signal!
What am I doing wrong?
Have you set up the TV Card to scan for Digital TV Channels in Media Centre setup?
:thinking:
andysp5
Hi Blencogo,
When I connected the Sky box, I configured 'Satelite', did a scan in MCE and it recognised the composite input.
When I connected my arial, I configured 'Terrestial', did a scan in MCE and it picked up nothing.
Any ideas?
Andy
