cant get my Memory stickpro Adapter OOOtt
geohfc
ive got a k415s dont know how to get the memory stick pro + adapter out the slot.
silly i know but nobody's perfect right
cheers:smileyconfused:
stevep-4
The memory stick should be on a spring release, like a ball point pen.
Just push the memorystick IN and it will then come out of the laptop enough for you to pull it out.
stevep-4
If you go to www.vaio-link.com you will be able to download the user manual for this model.
This should be a direct link,
http://www.vaio-link.com/manuals/manuals.asp?l=en&category=-1&serie=-1&m=1803
GO to page 67/68/69 and it will tell you all about using the memorystick,
kee-lo_
The worth thing about those adaptors is when you put them in Lexmark printers, they're hell to get out
