cd/dvd button not responding- pls help
lukemersh
I have just done a custom upgrade from Windows Vista 32bit to Windows 7 Ultimate 64 bit and now the button for the eject for the dvd player doesnt work.
Sony vaio VGN-AR51J
please help
jumpsuit
Hi lukemersh and welcome to the community :slight_smile:
Firstly have you downloaded and installed all the relevant updates from Here?
jumpsuit
olistone4
I had same eject button issue also after installing Win7 but on a VGX-XL
Here is the fix...
http://www.vgx-xl.com/support/eject-button-volume-keys-fix
Let us know if it helps fix your system,
Oliver
