I am desparately trying to find a way to increase the refresh rate on an external monitor attached to my laptop.
If I uninstall the ATI drivers downloaded from VAIO-Link the default windows drivers will let me change the refresh rate of the monitor but I cannot have both screens up and running to enlarge my desktop (and changing screens needs to be done using Fn+F7 on the keyboard). However, with the ATI drivers installed, I am able to get both screens running but I cannot increase the refresh rate of the monitor (it remains stuck on 60Hz).
Hopefully someone can help,
Shaun
But.......
Under the settings the screen is set at 60Hz with no other option to increase it unless I uncheck the box which says: "Hide modes this monitor cannot display".
Because the other Hz settings were not available until I unchecked the box do I assume that my monitor will only handle 60Hz?
Well uncheck it and then select 75mhz. If your monitor can't do 75Mhz it will probably come up as a big mess and Windows will force you back to 60. If it looks ok, then it can do 75.
Or you'll get a message "no signal" which should disapear within 30secs and back to normal.
Thanks guys:smileyhappy:
OK....
well, i my monitor can take at least 85Hz ( I havent tried to take it higher). In the advance display control panel, if i set the monitor to anything higher than 60Hz (ie something actally usable) nothing happends - the screen just sets itself to 60Hz. I've tried the latest drivers from Vaio-link and in the end I had to uninstall them as I would rather have 1 screen at a sensible refresh rate than the screen and the LCD with a silly rate on the monitor.
Anyone actually have any ideas on what's going on here?
Cheers,
Shaun
anyone have an idea?
i guess its a case of c'est la vie then.
