Hi there!!
i have a VGN-A197vp and i use 3dstudio and photoshop, but i have a problem that i cant solve and hope you can help me...
When i render an image in 3ds i think the image is ok but when i save it to a folder, the image get´s diferent... sometimes is darker sometimes is more saturated, this situation happends most of the times when i render it in 3ds it looks ok, i don´t understand... please help me.
Is it the color profile of the monitor? do i have to change the color profile of the software i use?
Tks a lot
You should work with the same color profile. For example, If you use the "sRGB Color Space Profile.icm" in Photoshop, then you should use it in Windows and 3D Studio too.
HTH
