Using a Netgear DG834G router with my T2XP. With WPA encryption enabled on the router, I get prompted for the key on the laptop as expected. With WEP selected, there is no prompt and the laptop just searches for the network and after about a minute tells me it couldn't connect, as expected!
Anyone else experienced this?
Yes, I had this but not with that laptop, had to get a new driver which supported WPA
Thanks KL, unfortunately my problem is the other way round, it's WPA that works and WEP that doesn't. Any other thoughts?
Cheers...
Jimbo,
The only thing I can think of is making sure they're both using 128bit for the passcode.
Or making a key and entering the code manually from the other PC
