Connect SONY Bravia-TV to FE11S and record AV (???)
roman_i
Hello,
Is there any possibility to connect
SONY Bravia flat TV to my FE11S ?
What soft- and hardware should I need to do it?
Any workaround will be welcome.
Roman
:thinking:
You can connect the s-video output from your FE11S to your TV's s-video input.
There is no way of getting a signal from your TV into your Vaio - it has no AV inputs. You would be better off getting a USB TV Tuner for your Vaio to record live TV.
Something LIKE THIS
:slight_frown:
roman_i
Thanks.
Roman
