Hi All,
I have recently bought a UX1XN and its just great for moving around with. Although I did have doubts about the screen size, they have now been blown away after using it for several weeks.
However, at home I would like to connect it to an external monitor. I have tryed a couple of monitors now, all have had a screen resolution greater than 1024 x 768 (which is the max resolution of the UX1XN) and the display on the external screen always comes up funny (the text is blurred). If I lower the screen resolution on the UX1XN itself down to 800 x 600 when connected to the external monitor, the screen is readable, although I do of course miss out on the higher resolution..... and the panoramic screen size.
Any ideas about how to resolve this? Is it possible to change the screen resolution on some external monitors? If not, what are my options? Any tips for monitors, preferably panoramic ones as well, to make best use of the desktop.
Thanks for any tips!
Pichichu, Madrid, Spain
