Difficult task? how to connect as a network my VAIO Desktop RA104 (with Wireless LAN ACCESS POINT) to a VGN-FE21M notebook (with wifi and blue tooth functionnality)
Any clue or link to document will be great
Hi mikur and welcome to the forum.
In Network Connections > Network Tasks, click ‘Setup a home or small office network’. Run this on both machines. You will then need to set share permissions for any folders or drives that you want to share – right click folder or drive and select sharing and security…..
You should then be able to access the folders from My Network Places or Windows Explorer.
You can download an interactive quide from HERE
