Connecting VAIO with BRAVIA
Djordje
hi there
im trying to connect my vaio VGN-AR21S with my bravia TV model KDL-32V2500
using Sony HDMI cable.
and my problem is that i cannot set resolution on my notebook to 1366x768 (wich is the nominal resolution of the HDready tv, you know :))
and the best picture quality im getting with 800x600 or 1176x664 or 1280x720
when i set it to 1360x768 (which is very close) the picture on the TV is oful (worstest).
is there any solution or thats the way it should be?
Thanks a lot
Best Regards
Djordje Vujicic
littlebucko
hi Djordje vaios use what they call a graphics processor and when you connect it to the same as a sony bravia this chip starts acting to make the picture the bast as possible and there more sets it to a certain resolution that best fits the chips inside the tv try using the manual screen resolution on the options and search for the best one but it will reset to default again when you reconnect to the tv again
Djordje
thanks!
the best resolution that works for me is 1176x664 and 1280x720.
maybe with some additional software i can make my chip work with 1366x768... but beside that, 1366x768 is old dead res without future :).
