Convert CD's to MP3 format
MrBell
Hi - I have a FZ21-S and I'm trying to convert cd's to mp3 to import into Movie Maker but can't find a 'built-in' converter - am I looking in the wrong place !!?
Thalamus.
Champion
Hi Mr Bell,
have you tried windows media player.?
Start Windows Media Payer, select Tools, then select Options.
Select the Rip Music tab and select MP3 from the drop down list in the Rip settings section under format.
Adjust the slider to your desired audio quality, then select Apply..
Insert your chosen CD and away you go.. :slight_smile:
