hiya guys
just a quick question it may sound dumb ...but i need to knw wot ''cpu'' meens and i need to know if its high is that bad and will it afect the laptop in any way
thanks
love bianca
xxx
[:">] :smileygrin:
Depends if you're doing ICT at school
Have a look Here
You can check your cpu usage by pressing ctrl-alt-delete and looking in processes.
High cpu usage can generally cause slowdown and your system to become unresponsive.
thanks guys for your help
love b
xxxxxxxxx
