Hi - just got my FE21M , created the recovery disks - now keen to remove the recovery partition.
how do i do this - ?
hopefully i dont have to go through a full recovery, ive got all my software and stuff installed and dont want to start again.
HI bigmark100,
Here is the Sony guide on how to remove the recovery partition
It would be a good idea to back up important data first..
Also it may be wise before you remove the partition to create at least 3 sets of Recovery Disc's, as some people have posted that the recovery disc that they created does not work and subsequently have had to buy a set from Sony..:smileywink:
