Hi all!
I am new to club-vaio - I recently bought a VGN-FJ1S/L and I am generally very satisfied with it.
Today I noticed a noise, when my notebook is switched off. It is kind of a high pitch noise comming from right under the PCMCIA slot on the left side of the notebook.
When I disconnect the battery, the noise dissapears, when I plug it back in, the noise is back.
It is not very loud, but you can hear, when it is really quiet in the room, or you put your ear towards the described location.
I am just curios if somebody else noticed this also and if this is a problem or not.
Thx very much in advance and best regards!
Wolfgang
Just wanted to say sorry - found several posts cocerning the problem when I used the "search" option.
Obviously some too have this noise - but it doesn't seem to be a problem.
Anyway I registered in the e-support, for the case it's getting worse.
regards!
Hi Wolfgang,
Welcome to Club Vaio,
Thanks for posting an update but there is no need to apologise..:smileyhappy:
Hi Wolfgang,
My battery does the same thing in the GRX316MP, and it's going to be 4 in September
