d3d on pcg fx701driver update?
phill1
:cry: is there an update for the rage mobility graphic chip which will support d3d or open gl on my vio fx701 none of the programs i have will run in d3d. ive tried the update from the sony site even had a look on Ati site but they say the mobility m1 is discontinued any advise please.
phill
TygerTyger
Every graphics card since the stone age should support Direct 3D. I would suggest you try reinstalling Directx from here .
