DDR2 memory bottle knecking
csducks
Hi guys,
Someone help,
I have a vaio VGN-A417M
i have ugraded the memory up to 2 gig using corsair PC4300 533Mhz x 2 modules
now according to the specs of the computer it run's at 533Mhz
as the FSB is 533.
However, now this is the problem.
they both only run at 266Mhz
whats going on.
is doing mi head in.
if you have the solution, and really can help
please email me at csducks@hotmail.com
kind regards
csducks
Also,
i know the original memory which comes with this laptop is PC2-3200 400Mhz, however using crucail website amongst others to find compatable memory
each one of those website list PC4300 as compatable memory for my system.
someone help me, how can i solve it, as it is ive spent £140 ish on something which seems is doing nothing,
at this rate the 2 x 256 chips are gonna get put back in,
:slight_frown: :slight_frown: :slight_frown:
Don't worry! This is normal!
The memory is DDR (Double Data Rate) memory. This means that the memory actually runs at a frequency of 266Mhz but it uses both the up and down cycles of each wave and so works twice as fast as the actual frequency.
Everything is OK and your new modules are working at an effective rate of 533Mhz.
:smileygrin:
EDIT: If you measure the actual speed of your old DDR2 400 modules, they will show as running at 200Mhz.
:smileygrin:
