Hello guys!
I would like to know if i can format the recovery partition!
I've made the recovery disks and i want to use the recovery partition because i think it would be very useful to have extra free space!
Thank you for your future answers!
Hi HateBreeder,
Here is a guide on how to delete the special recovery partition.
Remeber that once this partition is removed you will not be able to replace it, so make sure you have several copies of Recovery Disc sets just in case a set becomes lost or corrupted..:smileywink:
Thank you very much!
I'll make more copies of the recovery disks!
You're welcome HateBreeder, it would be wise to make at least 3 sets..
Good luck
At least!!!
