Disarming Sony Ar21M .. by MerlinPat ...To see images ...
profile.country.es_ES.title
pariope41
Regards gentlem. already I have put in another page the process of disassembly of the Ar, and it seems to me to be interesting to put it here. I will be putting it little by little and explaining it in the measurement of the possible thing, since not English ...original link http://www.pc-portatil.com/foros/YaBB.pl?num=1172419988 regards
35 REPLIES 35
pariope41
Windows Vista Ultimate runing in my Vaio...Full Hardware...http://www.pc-portatil.com/foros/YaBB.pl?num=1172419988
koymik
Nice Photos MAte!!!!
pariope41
Thank you very much for it of the photos. Estan done with a Sony R1. I will improve them when it(he,she) has the flash with the loaded batteries(sinks), that I have an external flash ... regards and I wait it you finds been of usefulness(utility)...In the attached link that I put teneis mas photos of the Ar...
Very good pictures patriciopat - you are a braver man than I am!
Have you changed the Core Duo processor?
Is it all back together now and working well?
:thinking:
pariope41
This is...
Intel Core 2 Duo T7200
- Tecnología multipolar Dual-Core
- Computación de 64 bits
- Velocidad reloj 2 GHz
- Velocidad del bus 667 MHz
- Zócalo de procesador compatible Zócalo 479
- Proceso de fabricación 65 nm
- Potencia de diseño térmico 34 W
- Características arquitectura Enhanced SpeedStep
technology, Intel Extended Memory 64 Technology,
capacidad de bit de desactivación de ejecución, Intel
Virtualization Technology
- Tamaño instalado L2 - 4 MB
- Tipo Advanced Smart Cache
The memory also I have changed it I him(her) have put two modules of 1giga ddr2 667 ... the original one goes to 533 ... it(he,she) is obvious a bit more in the yield...
Also I have changed the silicona and have put Silver Artic 5 .. and I have tested with more than 5 hard disks sata and they all work perfectly...
pariope41
In all that it(he,she) could I am going to measure the fps that the doom gives the IIIrd in Windows Dress to see the differences of yield ... that seems to you? Regards
pariope41
pariope41
pariope41
We disarm also the control distantly original Vaio Ar...
pariope41
The control distantly on the part of behind only removing 5 simple screws ... sony does not curtail in screws...
